Car is a 92 Camry LE Wagon V6 w/ABS
(pics below are big - use scroll bars)
This looks like a temperature sensor but I was told the coolant temperature sensor is threaded near the thermostat. As you can see, it's broken, so I would like to replace it but that might be easier if I knew what to call it. Also, what does it do?
It's threaded into a pipe that leads from the block to the heater hose(?). Other sensors/vacuum switches seem to use the same pipe. It has a 2-wire connector clipped onto the top; the wires descend into a large wire bundle and I can't really see what they attach to.
The engine runs reasonably well, though it does idle very fast (1700 rpm) when first started and I do have a check engine light with Code 71 (EGR).
Thanks for your help identifying this part; the car is new to me and I'm still waiting for the manual to arrive in the mail.
Best Regards -- thornfish
