1993 Camry LE Electrical Problem (Fuse?) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2009, 02:54 AM   #1 (permalink)
View SuperG's Photo Gallery
Question 1993 Camry LE Electrical Problem (Fuse?)
Hi all,
I have a 93 Toyota Camry LE, that has been working great. However, just recently, I have run into a problem. For some reason, the speedometer, odometer, the AC have all stopped working. The engine still turns and the car will work. It is really weird, because I can turn it on, and the headlights work, the radio works, etc. However, the speedometer doesn't work, the odometer doesn't work, the power windows don't work, etc. The thing is, I can still drive the car, but again nothing works on the speed/odom dials, and of course the AC won't come one. Any advice on how to fix this? Thanks.
SuperG
SuperG is offline   Reply With Quote
Old 08-02-2009, 07:15 AM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
To the left of the steering wheel, there is a little flip-out holder. Open it and push in the tabs on each side. Pull it out and you will have access to the small fuse panel. There is a 10 amp fuse for the gauges. Check and see if its blown.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
