94 4 cyl Driving Rough after Air Gets Cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2009, 11:51 AM   #1 (permalink)
View PharusCustos's Photo Gallery
Question 94 4 cyl Driving Rough after Air Gets Cold
I'm considering buying a 94 Camry, however the seller has told me that with the air on, the car will run great for about 20 minutes and then start riding rough. It runs great without the air on. Any ideas what could be causing this? Suggestions? Fixes? I love the car, but don't want to get stuck with a costly repair. I'm not sure if this is related, but I noticed that the air was much colder than I would have expected when I test drove it.
PharusCustos is offline   Reply With Quote
Old 08-02-2009, 10:30 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
So you can turn off the air and everything is smooth. And when you turn it off and then back on again, does it run rough immediately or after another 20 minutes?
Are both fans running? I wonder if AC is dumping too much heat into the radiator or if the compressor is seizing??
