cant get off the headlight lens' - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2009, 07:17 PM   #1 (permalink)
View jmac57's Photo Gallery
4th Generation cant get off the headlight lens'
i cant figure out how to clean the ugly stock lens' on my 97 camry ... i have the sandpaper and buffer but they are glued to the whole headlight config... do i just pry it off or what?
jmac57 is offline   Reply With Quote
Old 08-02-2009, 07:29 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
pop the housing in the oven to heat up the sealant, do again to re-apply. i think its like 200 degrees fro liek 5 mins is fine. then just pry it off. DO NOT try to pry off cold...youl will crack the lense.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-02-2009, 07:39 PM   #3 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
take it apart and take off everything else except the housing and the lens.
i baked mine in 250F for 15-20 minutes and I then could pry off the lens with my fingers
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is online now   Reply With Quote
Old 08-02-2009, 08:46 PM   #4 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
Alternatively you can use a heat gun to heat up the along all the edges where the sealant is, heat it all first and then start to pry it up. Keep adding heat to a few inches along the edge where you are prying it up and it'll loosen up as you go.
I like this method better since the rest of the headlight is cold enough to hold while you pry up the lens, reduces chance of burn injuries. Just make sure you don't put too much heat on the lens directly or it can melt/deform it.
Also, if it's a little hard to push the lens back on, you can heat it again to soften up the sealant.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline   Reply With Quote
Old 08-02-2009, 10:29 PM   #5 (permalink)
thanks guys will do in the morning
will i need to apply more sealant to reattatch? or will the existing stuff work?
Old 08-03-2009, 04:39 AM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
the exsisting stuff will work.
R.I.P.
Car Domain:
