high idle in PARK + rough in DRIVE + stuttering acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2009, 09:31 AM   #1 (permalink)
View njpnoy05's Photo Gallery
4th Generation high idle in PARK + rough in DRIVE + stuttering acceleration
ey guys. pretty much what the title says. at normal temp it idles at around 1500 - 1650 rpms in PARK or NEUTRAL. when in DRIVE it idles at around 900 - 1000 rpms. it's worse when the AC is running. almost feels like it is about to stall but never does.
as far as acceleration goes. it stutters at around 1500 - 2000 rpms from 0 - 20 mph. even at 50 mph going to 60 the engine really stutters. i added some techron cleaner thinking it was the fuel injectors before i filled up my last tank. that didn't do me any harm or good. i'm thinking about doing a second treatment.
i also hear a misfire type noise...could it be a faulty cylinder?
hopefully i'll only need to clean the IAC valve, throttle body, and replace/clean fuel injectors.
let me know watsup. thanks in advance.
njpnoy05 is offline   Reply With Quote
Old 08-05-2009, 04:06 PM   #2 (permalink)
View Judge2's Photo Gallery
I'd guess some sort of leaks in vacuum hoses, or even the air intake hose.
Judge2 is offline   Reply With Quote
Old 08-05-2009, 06:01 PM   #3 (permalink)
Gameroom cash: $303255
^ I have to agree with Judge2. Start troubleshooting by checking for vacuum leaks.
Mike
Old 08-06-2009, 12:32 PM   #4 (permalink)
Gameroom cash: $160210
View FLIP K1DD's Photo Gallery
3rd Generation
this was recently happening to my 94 until i took it to the shop and wasted money on a simple conclusion.
i changed fuel pump, filter, wires, coil, ignitor and spark plugs.
after all that the car was still running the same. so i took it to a shop, they said it was bad fuel injectors..so i took it to another shop before i spent 300$ on cleaning injectors plus another 100 to replace the bad injectors. the other shop said i had defective spark plugs..even though they were brand new, still looked good also.
changed them with an upgraded NGK lithium brand and bam. car runs great.
might i advise you to check the things you can do on your own before sending her away to a shop and wasting 100$ just for them to tell you your spark plugs are defective.
FLIP K1DD is offline   Reply With Quote
