Did you check on level ground, engine
running at operating temperature, cycled through all gears and then check? Parking brakes applied.
The fluid level should be between the two HOT marks. Otherwise sounds like the fluid is still good.
If the fluid is too high then just drain some out, or drain/refill the ATF with Walmart Dexron III compatible fluid. Costs ~$8 per gallon bottle. Works well. Fill it to the correct level and see how things behave.
The next thing, because it's a swap-in transmission, I'd check the
electrical connectors. Sometimes you have to disconnect and click them back on to work the contacts.
If that doesn't help you may need to drop the pan and check the solenoids to make sure they're working. And maybe examine the valve body at the same time.
If the problem is with the clutch pack apply pistons then it's either a rebuild or maybe Lucas Transmission Fix or HighMileage ATF.
Just my 2 cents.
Originally Posted by flex1016
i checked the fluid today and it seems kinda high... would too much fluid make the tranny do this ? is still red and doesnot smell burnt
