Yet again: problem with my clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2009, 02:26 PM   #1 (permalink)
View jaber's Photo Gallery
3rd Generation Yet again: problem with my clutch
Thanks to a lot of ya people I finally got my clutch free and soft:
[code]http://www.toyotanation.com/forum/showthread.php?t=301502[/code]
Now the problem is that whenever I'm stuck in a long jam, I have to keep the clutch pressed for a while, as the cars are moving very slowly.
This causes the clutch to loose its pump and its completely soft (cannot change the gear) and i have to let it go, and then after like 10- 20 secs the clutch automatically pumps back to normal pump level until i have to move slowly again, when it gets soft again!
I checked the master cylinder and the oil level is normal and clean and there is no leaks.
So what's the problem?
jaber is offline   Reply With Quote
Old 08-06-2009, 08:13 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Try bleeding the slave cylinder. After bleeding it, add fresh fluid and bleed it again. Do this several times until all the old fluid is out. Top off with fresh fluid. Also check for leaks. Pull back the boot on the slave cylinder. If its wet, replace it. Check the hard line for corrosion and leaks. I read your previous thread and it would seem that the slave cylinder and hard line have not been replaced. I would suspect the problem lies with either of those parts.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 08-06-2009, 11:05 PM   #3 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
This sounds very similar to what happens when the seal somewhere(maybe the piston? Don't remember) dislodges, allowing an initial 'bite' (of pressure building up), but then passes through the seal causing it to go soft and engaging the pressure plate against clutch. Happens to the brakes on dirtbikes occasionally.
Don;t know if you can get seal kits/rebuild kits, but if you can't, i think you might need a new master cylinder and/or slave.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 08-07-2009, 12:16 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
sounds like a bad seal in the master
HaHa
