[Help]97 camry 4 cylinder oil pan gasket? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2009, 01:06 AM   #1 (permalink)
View derick's Photo Gallery
I want to autozone, they do have a gasket. but when I want to toyota dealer, they said it has not gasket on it, it used a seal packagin 102(FIPG) part number:00295-00103.
my question is, what is good way to do?
derick is offline   Reply With Quote
Old 08-07-2009, 07:00 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i wouldnt use i gasket. i used high temperature RTV (the red stuff) and it works like a charm! here i am just about 50k miles later and not even a single prop.
Old 08-07-2009, 09:11 AM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
RTV / FIPG is wonderful stuff.
They come in different chemical resistance, temperature and hardness to suit application.
RTV 103 (formerly made by GE) is a soft (allows thermal expansion) FIPG.
The key is to get the mating surfaces clean - clean - very clean.
You can use any loctite/permatex (or other competetor) FIPG that list oil pan/trans pan for their application.
Grey FIPG that I have seen are stiffer and made especially for valve covers and brearing plugs and the like.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 08-07-2009, 07:25 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The original should be RTV (FIPG). You can use Permatex Ultra Grey.
http://www.permatex.com/products/Aut...sket_Maker.htm
However, traditional cork-rubber gasket is also available. Such as the $7.63 Fel-Pro OS30468C:
http://info.rockauto.com/Fel-Pro/Det...30468C_TOP.jpg
Just make sure surfaces are clean and oil free for both types. Otherwise they're more likely to leak. Personally I'd go with cork-rubber gasket for pans. I RTV water pump paper gaskets.
Old 08-08-2009, 12:03 AM   #5 (permalink)
Thank you all!
These information are very helpful.
Today, I bought the permatex ultra grey, butwhen I got under the car and look at the oil pan, I getup to do this. The screws are rust very much, unable to take it off.....
and I have to take many parts off before to take off the oil pan
I will post the pictures tomorrow.
Thank you again,
Derick
