power steering slowly dying - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2009, 02:55 PM   #1 (permalink)
View jmaddy10's Photo Gallery
I have a 94 5sfe and and recently I've noticed that my power steering is slowly dying. At first I thought it might just have been in my head, but every day it gets a little worse, especially at slower speeds. All I've done so far is check that there is power steering fluid, and there is plenty there. Does anybody have an idea what else might be going wrong? Thanks.
jmaddy10 is offline   Reply With Quote
Old 08-08-2009, 05:25 AM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Do you hear squealing when turning? Try flushing the out fluid and putting some new fluid in. If that fails, then i reckon you'll be needing a new pump.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 08-08-2009, 10:32 AM   #3 (permalink)
View RadioFlyer90's Photo Gallery
You know, my wife's '98 Camry is doing the same thing. I thought I was going nuts too, especially since my wife hasn't noticed any problem with the steering yet.
1990 Toyota Pickup, 2wd, 4-spd, reg. cab (sold!)
1998 Toyota Camry, 4cyl auto
1971 Toyota Hilux, 4cyl, 4spd, 4wd, 4 tires...
RadioFlyer90 is offline   Reply With Quote
Old 08-08-2009, 02:49 PM   #4 (permalink)
I haven't heard any sounds when it happens. It's weird because it seems to get worse the longer i drive, and when I start it up it's not quite as bad as the last time I drove it. I kinda got the feeling the pump might be the problem but I wasn't sure. If it comes to it I'll probably replace that.
Old 08-09-2009, 08:16 AM   #5 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
Replace the fluid first, it can be done easily with the car not running use a turkey baster and take fluid outa the reservoir and refill with new fluid..Run the car and repeat...This method needs to be done several times to get mostly new fluid into the system..Good luck...Dave
tacosteelersman is offline   Reply With Quote
Old 08-09-2009, 09:32 AM   #6 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
Use a high mileage ATF like Castrol/Pennzoil HM or Valvoline Maxlife. Fresher thicker fluid should help.
deadrx7conv is offline   Reply With Quote
