The lower the car the more it stretches the lateral control arms in the rear. If you go too low, then you hit positive camber.
I don't think 2 degrees is equal to a inner shift of 5mm.
Also if you lower the car but add + size rims then you balance a bit, but if you lower the car and get (-) size rims then you start to hit camber. But its hard to say cuz it depends on rims size, tire size, and ride height.
Your tire setup is neither + or (-) from the factory size so you should be fine. You should have minimal camber
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
