head gasket removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2009, 10:50 AM   #1 (permalink)
View southwestdream74's Photo Gallery
head gasket removal
My girfriend Toyota camry 93 4 cyl Head gasket is leaking , i`m planning to changed , i remove almost everithing , now i don`t know how to remove the intake and exhaust cams , i read the manual and say something about the knock pin to be in some way , but i don`t understand , please any help will be really appreciated . thanks
southwestdream74 is offline   Reply With Quote
Old 08-08-2009, 09:10 PM   #2 (permalink)
View majones's Photo Gallery
I've done this several months back. From what i remember the shaft toward the front of the engine has a couple of "gears" toward the passenger side and as i remember these are positioned to line up and a bolt is put in place to keep them from turning relative to one another. Once locked in place the manual gives a specific order for loosening the bolts; this keeps the stress on the shaft evenly distributed so it doesn't get bent. Definately consult the manual but i believe the knock pin alignment described has to do with getting the "gears" aligned so you can lock them together with a bolt.
majones is offline   Reply With Quote
Old 08-08-2009, 10:08 PM   #3 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Correct me if i'm wrong, but if you're replacing the head gasket, i don't think there's a need for you you to remove your cams. Just lock them in place, slip the timing belt off and unbolt the head from the block in the correct sequence.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 08-09-2009, 10:42 AM   #4 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
your wrong.
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 08-09-2009, 07:09 PM   #5 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
yup! toyota in notorious for doing this, but in order to take the head off, cams HAVE to come off. The head bolts are underneath the cam shafts and are usually a 12pt nut. i removed my 4age head and my 7afe head...its a pain you have have to remove the head bolts in a specific order also
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
