Find the leak
Hi all,
I'm trying to find the source of my leaking tranny fluid in my 94 camry 5sfe automatic. I've changed the transmission pan gasket (twice actually) and that may have contributed but don't think its the only source.
The leak is on the drivers side, i've cleaned it and it came back... there is a drip off the transaxel case (I've tightened the drain and fill plugs...mine had washers on the plug bolts but no rubber seal or anything... not sure if its supposed to). Feel like the leak may be up alittle higher on the tranny and dripping down but thought i would see if there were common leak spots so i have an idea what to look for before getting back under the car. Not sure if there might be a powersteering component or hoses over towards the drivers side that might be the culprit also since it uses ATF also.
Any thoughts would be appreciated, thanks!
