Grounding to negative wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2009, 08:51 PM   #1 (permalink)
View gyz1893's Photo Gallery
When I listen to my radio/cd, I hear a light hum/buzz through my speakers whenever I step on the accelerator. Through my research, it seems like I have a ground loop. I have read that connecting the ground wire on my cd player to the negative terminal of my battery will fix the issue. Do I have to run a wire directly from the battery to the CD player? Or can I just join the ground wire to the negative wire thats already there?
gyz1893 is offline   Reply With Quote
Old 08-08-2009, 09:05 PM   #2 (permalink)
View lenjack's Photo Gallery
I don't think t's a ground loop. Wait for others to chime in.
Any car problem can be fixed with a large enough hammer!
lenjack is offline   Reply With Quote
Old 08-08-2009, 09:11 PM   #3 (permalink)
It fits the description of an alternator noise. To me, alternator noise is the same as a ground loop. Please correct me if I am wrong.
Old 08-09-2009, 12:31 PM   #4 (permalink)
I agree that it is alternator noise, but I don't think that's the same as a ground loop.
Old 08-09-2009, 03:41 PM   #5 (permalink)
View Manny1337's Photo Gallery
i had the same issue. you need a group loop isolator on the rca =P. if youre not running an amp then use the ground wire from the stereo right to steel. make sure there is no paint on the connection and its bare metal.
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Manny1337 is offline   Reply With Quote
Old 08-09-2009, 07:05 PM   #6 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Agree with Manny as well..
If not, would suspect alternator bearing... not sure how the Toyota ones work but had same problem with friend's Datto with the same noise.
whip_cracker is offline   Reply With Quote
Old 08-10-2009, 11:07 AM   #7 (permalink)
thanks for your suggestions guys. i will try grounding to the cage brackets. Also, (sorry to be a pain in the a$$) I have listened to radio and a CD while the car was in "ACC" mode. I still heard some static coming out of the speakers. Could something else be wrong?
Old 08-10-2009, 05:06 PM   #8 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
What type of head unit do you have? is it a Pioneer by chance?
SexieWASD is offline   Reply With Quote
Old 08-11-2009, 08:45 AM   #9 (permalink)
Nope, I have a Nextar brand. Here it is: http://www.newegg.com/Product/Produc...82E16882558021 Picked it up cheap for $20.
Old 08-11-2009, 11:43 AM   #10 (permalink)
well that your issue then lol. buy something better quality
Old 08-11-2009, 11:49 AM   #11 (permalink)
lol i should. but i am on a tight budget (school, gas, etc...) Is grounding to the cage of the head unit a good idea?
Old 08-11-2009, 04:53 PM   #12 (permalink)
yeah as long as its baremetal anywhere will do
Old 12-14-2009, 11:31 PM   #13 (permalink)
95 5S-FE
CROYCE992's Avatar
View CROYCE992's Photo Gallery
pardon the ignorance, what is a group loop isolator? I cant seem to find much information on google or where to buy one for product descriptions.
4T 6M1 1995 Toyota Camry 5S-FE DX AT Sedan - 171k miles
CROYCE992 is offline   Reply With Quote
Old 12-15-2009, 01:14 AM   #14 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
^ it's a ground (not group) loop isolator. A ground loop is when the ground at one point in the car (i.e. stereo up front) is at a different voltage potential than at the ground at another point in the car (i.e. amp in the back). This potential difference will cause a slight DC current through the ground of the signal (RCA) wires. This DC current will produce unwanted noise when amplified.
Ground loops can usually be caused by poor grounds in a car in conjunction with large current pulls from appliances such as an amplifier. Since a poor ground can be seen as an electrical resistance, R, and the current drawn by an amp in the rear, I, passes through this resistance, the potential difference between the two ground points will be IR.
A ground loop isolator is basically a transformer with a 1:1 turns ratio. Since a transformer is magnetically coupled from side to side, not electrically coupled, this DC current cannot pass through it. The audio signal is an AC signal, so that can pass through the transformer. This transformer then passes through the audio signal and effectively filters out the ground loop.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 12-15-2009, 11:55 AM   #15 (permalink)
95 5S-FE
CROYCE992's Avatar
sounds like something i could use. on rare occasions i seem to be getting a little noise like the subs are trying to reproduce vocals which might have more to do with my crossover tuning. anyways, this seems like a smart investment. where can i get these and are they hard to install?
