Gasoline smell in oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2009, 10:19 PM   #1 (permalink)
View shuresh's Photo Gallery
Hi there,
I have a Camry 99 4 cylinder with ~200,000 Km on it. I was doing a routine oil level check this evening ad noticed a strong gasoline smell when I removed the oil dip stick. I wonder if this is/is going to be an issue as I have never experienced such strong smell before. I have recently migrated to high mileage oil.
Thanks,
Shuresh
shuresh is offline   Reply With Quote
Old 08-09-2009, 01:31 AM   #2 (permalink)
Experts,
Any thoughts?
Old 08-09-2009, 05:47 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Not an expert but you shouldn't be able to detect fuel in the oil. Leaking/dripping injector, piston ring blow-by, rich running. Fuel in oil will reduce the lubricating properties of oil. You can send the injectors out for testing and repairing. Do a compression test. Send oil sample to lab to determine what % fuel in oil.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-10-2009, 12:33 AM   #4 (permalink)
Thanks Stillrunning for your points. Any other thoughts? Actually, I have had engine check light on for quite a long time with P0401 code. Can this be related to the the error code?
Thanks,
Shuresh
Old 08-10-2009, 05:59 AM   #5 (permalink)
http://www.obd-codes.com/p0401
If you mean could a p0401 lead to gas in the oil, I doubt it.
Old 08-10-2009, 08:08 AM   #6 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
I'm no expert either, but I'm thinking maybe you have excess fuel left in the pistons that's not burning and its seeping into the oil. Engine has high mileage and unless you've changed out the rings, maybe they're letting some gas through when there's fuel sitting in there. Mostly happens on cold starts with short drives before the engine has a chance to fully warm up and you leave the car sitting for an extended time.
You should really consider changing the oil and filter if the gas smell is that strong, gas breaks down lubricating molecules of the oil and bad oil can cause more problems.
Have you done a tune up recently? Might help burn the excess fuel with a simple tune up.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is online now   Reply With Quote
Old 08-10-2009, 08:00 PM   #7 (permalink)
Thanks everybody for your feedbacks. Sounds like I need to show the car to a professional mechanic.
