stuck strut nut - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2009, 05:21 PM   #1 (permalink)
View importcar's Photo Gallery
4th Generation stuck strut nut
My impact gun rated at 220 ft lbs won't budge it so I ran out and bought a 24" breaker bar. I gave it everything I got with the bar and it still won't budge. WD40'd the nut, used a car jack and it still won't budge. The breaker bar is actually bending (see pic).
Any suggestions?
2001 Camry LE 5S-FE
importcar is offline   Reply With Quote
Old 08-09-2009, 05:34 PM   #2 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
Maybe I'm looking at it wrong, but with that jack set up to push the bar up, wouldn't that tighten it?
The way I'm seeing it, you should be pushing it down to loosen it.
If I'm wrong, try a penetrating lubricant instead of just WD40.
If that doesn't work, you can heat it up to expand the metal, not sure if that's a good idea for the strut though.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is online now   Reply With Quote
Old 08-09-2009, 05:42 PM   #3 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
my electric dewalt impact wrench gun works fine, make sure you turn it at the nut, not the bolt, if your 24" extension didn't work for you, you probably can go to homedepot fence section, and buy a 6 ft pole/pipe extension, it works fine for me before i bought my dewalt from lowes, 345ft/lb, 2700 impact per minute, my 6 ft pipe still works well, but impact gun is a lot easier.
here is the link
http://www.lowes.com/lowes/lkn?actio...92K&lpage=none
i found the gun very useful, it works for my crankshaft bolt, big druve axle nut, the trick is i have to keep the object from loose or spinning, so it doesn't obsorb the impact force.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 08-09-2009, 06:13 PM   #4 (permalink)
Gameroom cash: $283230
View LE05's Photo Gallery
you're right... he's tightening it, not loosening it! come on... everybody should know this: righty tighty, lefty loosey. no wonder the OP can't budge it... its going to be even harder to loosen it now.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 08-09-2009, 06:51 PM   #5 (permalink)
OMG you are right I was tightening it!!! I was about to call it a day but I'll go back and loosen it the right (lefty) way. I'll check back later. THANK YOU!
2001 Camry LE 5S-FE
Old 08-09-2009, 08:43 PM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
Old 08-09-2009, 09:44 PM   #7 (permalink)
Done! I was able to loosen it by pushing down with my full body weight. I bounced on the bar a couple of times and the nut came loose. The passenger side nut was loosened by pushing up, so without checking, I did the same on the driver side. Big mistake. The lesson to be learned here is to check the bolt threads before doing it
New strut next to the old strut
New strut installed
2001 Camry LE 5S-FE
Old 08-09-2009, 11:01 PM   #8 (permalink)
View dcninja757's Photo Gallery
this thread is classic!
dcninja757 is offline   Reply With Quote
Old 08-10-2009, 11:08 AM   #9 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 08-10-2009, 12:07 PM   #10 (permalink)
View titleist's Photo Gallery
new member thanking you for the laugh.
titleist is offline   Reply With Quote
Old 08-10-2009, 03:15 PM   #11 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Nice job importcar. It happens to the best of us (even me!). DxElite was right on.
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
Old 08-10-2009, 09:08 PM   #12 (permalink)
ghettosled's Avatar
while you are working on the car, make sure to top off your blinker fluid.
Old 08-10-2009, 10:49 PM   #13 (permalink)
har har har
2001 Camry LE 5S-FE
Old 08-11-2009, 10:26 AM   #14 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
Lol!
RU2CHKN is offline   Reply With Quote
Old 08-11-2009, 02:02 PM   #15 (permalink)
stancati's Avatar
View stancati's Photo Gallery
Canada
This is classic
Everytime you try and loosen or tighten a bolt, you should think to yourself ...
"Righty Tighty ... Lefty Loosy"
Not trying to be rude, but before you work on a car, you should definitely know the basic mechanics of hardware. It would be really shitty if you went underneath your car and then realized that the jack stands or the jack itself is placed incorrectly, and KABOOM your dead or critically injured, that would be a kick in the nuts, eh
This is a good reminder that everyone should be safe when working on there cars, "Think twice then Do once, or you may not Do anything again" Alot of people dont realize how dangerous a car can be, especially when its not moving.
and oh, i just found the "more smilies" section... , dont know when anyone would use this one, lol
stancati is offline   Reply With Quote
