No oil in oil filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2009, 08:37 AM   #1 (permalink)
View naterice's Photo Gallery
I changed my oil last week and discovered that the oil filter still looked brand new and unused. The mileage between changes was about 5000. I have a 1996 Camry 4-cyl with 178k. The oil filter was a Bosch. I did not see an obvious clog on the engine block or in the filter. No unusual engine performance has been noted. No check engine or oil pressure lights came on.
I changed the oil as usual and put a new Bosch filter on. A few days later I pulled the filter and it still looked like no oil had reached it. Any suggestions? Thanks!
nate
naterice is offline   Reply With Quote
Old 08-10-2009, 09:16 AM   #2 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
Has this happened before or is this your first time changing your oil for the car?
Since the filter is mounted angled down like that, it's normal for the oil to drain out and look like there's no oil in the inner part of the filter, but there is oil in the outer casing.
If you want to really see it, you can try cutting open an old filter or crush it to see if there really is any oil or deposits. Since there was no unusual engine performance issues, doubt there's a problem.
But you can, drop the oil pan and check the oil intake screen for clogs.
I know I was surprised the first time I changed it for my car. I'm used to having a rag ready to wipe the oil that spills but it was a clean removal. All the other cars I've changed the filter for were bottom faced down or horizontal so there was always some oil left in the filter. Personally I like the clean filter removal, much less of a hassle.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is online now   Reply With Quote
Old 08-10-2009, 09:29 AM   #3 (permalink)
I have changed it many times before and some oil is always left in the filter (maybe 1/4 cup or so). This time it looked new and dry inside the filter.
How hard is it to find and clean the filter intake? Are the two hoses that are adjacent to the filter from the oil pan?
Thanks for the help.
Old 08-10-2009, 09:54 AM   #4 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Hmm are you sure the filters just not draining out on you?
Theres really no way that the filter couldn't be getting oil to it, without the engine being toast.
Cut it open, but there's a 99.99999% chance that everything's fine, considering your car runs fine.
carsrus is offline   Reply With Quote
Old 08-10-2009, 10:00 AM   #5 (permalink)
DxElite's Avatar
Have you always been using Bosch filters? Maybe there isn't an anti-drain back gasket for it?
If anything, you can check the oil pressure with an oil pressure gauge to really be certain that there's oil being pumped.
Old 08-10-2009, 10:55 AM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Nate,
The oil in the center portion of the filter drains into the engine block once the engine oil pump stops. If this filter does look dry, and you want to just be sure, do what Carsus suggested and cut it open. If you just want an indication, punch the can open with a screwdriver.
Dx,
The Bosch filters that I have seen appears to have a very good anti drainback valve, so good that there may be no oil spilling out when it was being removed.
But a faulty anti-drainback valve is not impossible.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 08-10-2009, 05:10 PM   #7 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
What number filter is it?
SexieWASD is offline   Reply With Quote
Old 08-10-2009, 05:41 PM   #8 (permalink)
The model number is 3311, Bosch Premium Oil Filter - in a black box from AutoZone.
I punched a screwdriver into the end of the old filter and a bunch of oil poured out. So I guess they improved the anti-drainback valve from the last time I changed the oil.
Old 08-10-2009, 07:03 PM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
It's a lubrication system design problem, not an oil filter problem. Bosch Filtech (they also bought Purolator) makes a decent filter.
nate
