a/c guage and window fuse blowing? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2009, 01:57 PM   #1 (permalink)
ydopen's Avatar
View ydopen's Photo Gallery
It blew and I put a altonator on it before I knew it was the fuse. the fuse was a 10. and when I put a 10 in it it last for a few sec and blows. then I put a 15 in and it lasted a few hours and blew. then a 25 and it was fine? But something aint rite? has anyone had this prob?
11 Camry Se 4cyl,
95 Camry v6 17in o8 camry wheels. Tint.
83 toyota pk. Longbed automatic all-original.
98 Expedition 16in rebel racing black rims.
01 Chevy Metro
ydopen is offline   Reply With Quote
Old 08-10-2009, 06:04 PM   #2 (permalink)
View djb2's Photo Gallery
You should never install a higher amperage fuse in place of the original.
Well, unless you have given up on finding the problem the safe way and plan on finding it by tracking down the source of the fire.
A short circuit drawing 20 amps at 12 volts will generate a lot of heat. It won't take long to find the problem.
djb2 is offline   Reply With Quote
Old 08-10-2009, 06:21 PM   #3 (permalink)
ydopen's Avatar
Ok thanks it's at my buddys shop now. Just trying to get the word out to see if this is an occuring problem on this make and model? to make a quick repair.
11 Camry Se 4cyl,
01 Chevy Metro
Old 08-12-2009, 11:37 AM   #4 (permalink)
View walt19's Photo Gallery
Does the 10 amp fuse only blow when you move the shifter into reverse? If so here's what to do.
I just went through this. It was hard to spot the frayed wires for the back up lights in the trunk bundle. Had to remove the padding on the left side of the trunk since the problem was right where the bundle disappears into car body. Had to climb into trunk with flashlight to tape them up. No more blown 10 amp fuses.
walt19 is offline   Reply With Quote
