Yes, there are a number of things, as mentioned, that may need attention.
I'd use NGK Iridium-IX or if you want a cheaper plug the NGK G-Power platinum. Both of these have smaller center electrodes. But I think plugs are low on the list causing your current problem.
Besides idle air valve and fuel filter, I'd also dump a can of
Chevron Techron Fuel System Cleaner into the tank and check for carbon build up and smooth operation of the
EGR valve. You may also have
vacuum leaks from hardened rubber gaskets/seals.
Originally Posted by felpz123
i just bought my 94 camry 4cyl used about 2 months ago, and havent had a chance to do anything other than oil change.
occasionally, usually after not driving for a day or two, i will start my car and it will stutter, and sometimes die if left idling. when accelerating, it'll accelerate, then pause, then accelerate, sort of like there is trash in the fuel tank but i am 100% sure thats not it.
im wondering if this is a problem with my spark plugs or something else?
thanks
