2.2l engine noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2009, 10:44 AM   #1 (permalink)
View giterdun's Photo Gallery
2.2l engine noise
Hello ladies and gents, Im hoping to get some help for my 01 camery with a 2.2. The engine when started makes a loud metallic knock on what seems to be the top end, its there constantly and speeds up and slows down with engine rpm. Crazy thing is that the motor runs fine other than the knock. Ive tried changing the oil to no avail. The best that I can tell its coming from the front portion of the engine somewhere in the valve train. Any and all help would be greatly appriciated.
giterdun is offline   Reply With Quote
Old 08-11-2009, 11:51 AM   #2 (permalink)
View murphy390's Photo Gallery
It may be a frayed timing belt hitting the cover at the top end. Any idea as to when it was changed? On '01's they're good for 90K miles.
murphy390 is offline   Reply With Quote
Old 08-11-2009, 12:09 PM   #3 (permalink)
I just looked at the belt as a friend of mine suggested something similar it looks okay (not frayed but time to be replaced: cracking). Taking a closer listen it really sounds like its coming from the valve train, but Im just not sure how since I read that this is a non inerferance motor. Could it be a lifter or spring?
Old 08-11-2009, 12:19 PM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
I had a 96 5sfe, that made a similar noise, and it ended up being the Timing Belt tensioner. Be sure to replace that with the TB.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 08-11-2009, 01:02 PM   #5 (permalink)
Okay thanks, Ill look at that as well.
Old 08-11-2009, 02:25 PM   #6 (permalink)
Just so you know, you can't see the timing belt, it's behind the plastic cover on the far left side of the engine (looking from the front of the car). The belts that are visible are the alternator, ps, ac drive belts. If you do a search on timing belts you'll find lot's of info including a DIY replacement.
