Headlight problems...still - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2009, 11:39 AM   #1 (permalink)
View matthewromero's Photo Gallery
I posted this thread about two weeks ago, but I have not received much input, so I'm trying again.
The thread as follows:
I have a 99 Camry. The low beam headlights do not work. The high beams work just fine; both in the flash position and the high position.
I checked the combination switch, and it seems to be working as advertised in the Haynes manual.
Both the DRL relay and the Head relay seem to be operating satisfactorily. I know they are good because I swapped the relays and the problem remains the same.
It looks like the integration relay may be the culprit, but I need to test it before I swap it out. My problem is this: the Haynes manuals are not thorough enough in the headlight section.
Can anyone provide me with an accurate wiring diagram for this car?
Can anyone provide me with an indication of where to find the "Integration Relay"?
I appreciate any help I can get from this unique community. Thanks.
Sincerely,
Matt
One response asked me if I had two inoperative low beam light bulbs. I checked for power at both jacks and the power is good to go.
I need an accurate schematic diagram for this system. I'm currently working off of a generic Haynes manual, but the diagram does not accurately represent the system.
Can someone please help me?
Matt
matthewromero is offline   Reply With Quote
