a/c cools for some time and then blows hot air - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2009, 03:54 PM   #1 (permalink)
View niknavin's Photo Gallery
Unhappy a/c cools for some time and then blows hot air
Hi!
I have a 96 camry LE with 87K miles on it.
Till not A/C was working perfectly but now it starts by giving very cool air just like it should. After about half an hour it stops giving cool air. Depending on outside temperature it starts giving hot/ warm air.
I am South FL, so during afternoon when it is sunny it feels as if heating is on at max.
I am hoping it will not be very expensive repair. Will I be able to fix this problem my self? If not how much it can cost?
Just for your info:
About 2 months back the screeching sound started - just when I start my car and start a/c it gives a screeching sound for first few min. According to what I have read here and on other sites - most likely it is because of the belt - I have not changed the belt yet.
Thanks,
Niks
niknavin is offline   Reply With Quote
Old 08-11-2009, 05:12 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Originally Posted by niknavin View Post
Hi!
About 2 months back the screeching sound started - just when I start my car and start a/c it gives a screeching sound for first few min. According to what I have read here and on other sites - most likely it is because of the belt - I have not changed the belt yet.Niks
So, check belt condition/tension and change/tighten if necessary.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-11-2009, 10:13 PM   #3 (permalink)
Gameroom cash: $105400
View dz63's Photo Gallery
^+1 The screeching sound is likely due to the AC/alternator belt slipping. I have had to tighten mine a couple times after replacing the belt last August. The belt is cheap (< $20) and it is easy to change. I would try that first. I think the belt stretches a bit after awhile, so you may need to tighten it up a bit like I did.
2002 Camry 2.4L Auto - 70K miles
2008 Corolla 1.8L Auto - 48K miles
dz63 is offline   Reply With Quote
Old 08-11-2009, 11:09 PM   #4 (permalink)
Thanks for your replies. I am going to change the belt very soon.
But do you think that ac stops cooling because of the belt?
Old 08-12-2009, 06:49 AM   #5 (permalink)
I think there is an RPM counter for the compressor, if it slips then the A/C stops working. Could also be compressor clutch. If not then get pressures checked.
