Left side rear axle? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2009, 07:55 PM   #1 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
The back left tire on my car is bent in a little bit. The tire has an uneven tread and you can see that the tire sits unevenly when you look from behind.
I'm assuming someone hit a curb. What exactly is the part called that's bent? Axle, CV Halfshaft?
And where could I buy this part for cheap? Local Autozone wants 60 bucks + tax for a CV Halfshaft. (If that's even it).
Thanks for the help.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 08-11-2009, 09:00 PM   #2 (permalink)
View bmxr4life87's Photo Gallery
there are no axles on the rear only control arms. I would suggest taking it to a dealership or alignment shop and asking them to look around under there or see how close to spec they can get it
bmxr4life87 is offline   Reply With Quote
Old 08-11-2009, 09:06 PM   #3 (permalink)
TN's bilingual ambassador
View Gerson's Photo Gallery
It can either be a bent strut, knuckle, or perhaps the rear control arm if its way out of spec. They'll be able to tell u when they perform a diagnostic alignment check. Hopefully tis nothin major for u so u can save some money, good luck.
92 ウィンダム (ES300) VCV10L-BTMGKA 3.0L 3VZ-FE w/E53 5 speed
http://www.cardomain.com/ride/3302985
Gerson is offline   Reply With Quote
Old 08-11-2009, 09:20 PM   #4 (permalink)
Slowly learning....
I was going to go put on new tires at Sams Club this weekend and get an allignment done right away. I don't want to put on new tires and have them tread unevenly right away.
I guess I'll call Sams and see if they can look at it first.
Old 08-15-2009, 10:25 AM   #5 (permalink)
Slowly learning....
I took it to a shop that my dad trusted, they inspected it for a little bit and gave me some really, really bad news. They said the whole assembly needs to be replaced. Knuckle, strut, control arm, everything. They ordered the whole assembly from a junkyard (with warranty) and are replacing it.
250 dollars for parts + labor.
My wallet. It burns.
Old 08-15-2009, 02:41 PM   #6 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
$250 sounds like a good price.
SexieWASD is offline   Reply With Quote
