re-installing VSV - help needed
I had a P0401 code on my 2000 Camry. Diagonosed the problem, found the VSV to be the problem.
I changed the VSV, which is attached the engine block under the intake manifold. I reset the CEL and after several days, the CEL hasn't reappeared and the CEL problem seems to be fixed :-)
The Bad: I could not re-attach the bolt that attached the VSV bracket to the engine block. The best access (if you can call it that) is from the passenger side wheelwell, but I cannot with one hand hold the bracket, locate it, insert the bolt and tighten it at the same time.
If anybody has some tips on how to do this, I would appreciate it. For the time being, I zip-tied the VSV to the rear engine mount so it would stay.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
