WHY is my ABS light on ? PLEASE HELP ! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2009, 06:20 AM   #1 (permalink)
iratoyota's Avatar
View iratoyota's Photo Gallery
3rd Generation WHY is my ABS light on ? PLEASE HELP !
My 94 Camry V6 XLE(70K) has the ABS light on. My brakes don't squeak or feel spongy. No symptons at all. All the pads,rotors and calipers were replaced at 49K . It just went on yesterday and have only driven 15 miles to get home from work. Please advise. Thanks !
iratoyota is offline   Reply With Quote
Old 08-12-2009, 08:09 AM   #2 (permalink)
View Lightning Blue's Photo Gallery
Speed sensors might need looking at?
2001 Camry LE - I4 - 138,xxx miles
2005 Neon SXT - 47,xxx miles
Lightning Blue is offline   Reply With Quote
Old 08-12-2009, 08:12 AM   #3 (permalink)
View titleist's Photo Gallery
go to the shop, get the code, replace the corresponding wheel speed sensor. fixed.
titleist is offline   Reply With Quote
Old 08-12-2009, 09:57 AM   #4 (permalink)
iratoyota's Avatar
thanksfor the prompt reply. what is a speed sensor and how much is it? is a part for each wheel or is it 1 piece for all 4 wheels ?
Old 08-12-2009, 09:58 AM   #5 (permalink)
iratoyota's Avatar
will they hook my car up to a machine to diagnose this? any guess on the price of the part and or repair from a shop or is this a DIY type of fix ?
thanks for the help
Old 08-12-2009, 09:59 AM   #6 (permalink)
separate part for each wheel. it picks the speed of your cv shafts and when one wheel speeds up or slows down faster than the others, it turns your abs on to keep your car going straight when braking
Old 08-12-2009, 10:01 AM   #7 (permalink)
once you know what sensor it is, (diagnostic hook up), you can replace it yourself, the sensor would be cheaper at a wrecker if you can find one that isn't broken. they sometimes break from corrosion when being removed. as per price? you will have to shop around.
Old 08-12-2009, 11:52 AM   #8 (permalink)
iratoyota's Avatar
thank you. i will have it hooked up and go from there
