power steering fluid leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2009, 09:18 PM   #1 (permalink)
View took's Photo Gallery
Question power steering fluid leak
My 97 Camry LE seems to have power steering fluid leak. When the steering wheel is turned, I can see oil dropping beneath the car (somewhere near the power steering fluid tank). If I drive the car and make a sharp turn, there's a continuous oil trace on the ground. The power steering fluid was refilled last week, and since then I've only driven the car for maybe 20-30 miles, but the fluid level is already well below the min level.
The mechanic shop asks for $180 to fix it. I'm wondering if it's a reasonable price.
Also, could I just use "power steering stop leak" as a temporary fix, which seems a much cheaper choice?
Thank you in advance.
took is offline   Reply With Quote
Old 08-12-2009, 09:39 PM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Sounds like the high pressure hose has gone bust if it increases when you turn the wheel. I hate those fluids claiming 'stop leak', while it may work, it will generally reduce the efficiency of the system. I replaced my high pressure hose myself and it cost $50 for the hose. So $130 for labour.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 08-12-2009, 10:30 PM   #3 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
Consider yourself lucky if it's just the hose leaking.
This is what happened to mine.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 08-13-2009, 11:15 PM   #4 (permalink)
セクシーの定義
For a second i thought you meant ur 'new' rack screwed up too!
Camry history:
