Breaks dont work on my Gen 3 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2009, 10:10 PM   #1 (permalink)
View gyz1893's Photo Gallery
Brakes dont work on my Gen 3 camry
Earlier today when I was driving to school, I tried to apply the breaks but the car would not stop. I had drive extremely slow and use the hand breaks to drive to school and back (~45 miles round trip, not my best idea). I took the car to a mechanic who says the lines that carry the break fluid (or what ever) has broken. He says it will cost $150 to replace lines. Is that a good price? or is this an easy repair to do on my own for a fraction of the cost?
gyz1893 is offline   Reply With Quote
Old 08-12-2009, 11:00 PM   #2 (permalink)
TN's bilingual ambassador
View Gerson's Photo Gallery
If he's replacing them make sure he show u the old ones and bleeding the brakes also part of the cost. if it is then thats pretty reasonable.
92 ウィンダム (ES300) VCV10L-BTMGKA 3.0L 3VZ-FE w/E53 5 speed
http://www.cardomain.com/ride/3302985
Gerson is offline   Reply With Quote
Old 08-13-2009, 08:47 AM   #3 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
yeah sounds reasonable i just had my brake lines replaced not too long ago
RU2CHKN is offline   Reply With Quote
Old 08-13-2009, 11:02 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
did the mecahnic mention whether its for the front or back? is he replacing the whole line or just the bad section? if the rear lines rusted through, odds are the fuel lines are about to go and will probably do so when the brake lines are replaced. just a heads up.
Old 08-13-2009, 07:46 PM   #5 (permalink)
He did not mention if it was the front or the rear. He just replaced both of the lines. How do the fuel lines come into play with the break lines?
Old 08-13-2009, 08:01 PM   #6 (permalink)
View titleist's Photo Gallery
sounds like you are going to be replacing the brake and fuel lines. they run together in a little plastic shield. they corrode together and after about 10 to 12 years, need to be replaced. condensation and rain water sits right in front of the gas tank underneath the car on the lines, and this is where they leak first. the brake lines go first due to higher pressure inside them. when they are replaced, your corroded fuel lines will break. do yourself a favor and just replace them all at the same time. put the vehicle up in the air, pull the plastic back and you will see your blistered lines.
titleist is offline   Reply With Quote
Old 08-14-2009, 11:02 AM   #7 (permalink)
I see... So is this an easy job to do on my own? I dont want to fork over another $150 if I can just do it myself.
Old 08-14-2009, 11:07 AM   #8 (permalink)
in canada, you would probably be looking at buying the oem parts for approx $350 to $450. if you were going to make them, probably $40 for brake line, plus $50 for a flaring kit, plus fuel lines, which you can't make. you will need a hoist. as far as time... my best was about four hours doing it properly. making your own lines and if it is your first time, expect about 10 hours. make sure you use a double flare, or else they will leak.
Old 08-14-2009, 11:12 AM   #9 (permalink)
lol i thought it was as simple as just using a couple of rubber tubing's along with some clamps. looks like i will have to ask my mechanic if he replaced the fuel lines when he replaced the brake lines. Otherwise I will be putting down another $150...
Old 08-14-2009, 06:14 PM   #10 (permalink)
View tran.man48's Photo Gallery
I say $150 is a steal...I just had this done, and 2 new front lines ended up being around $300 incl. labor....then again, I'm in hawaii and everything is more expensive here.
Originally Posted by Zembonez View Post
Nothing is impossible with enough money and beer.
tran.man48 is offline   Reply With Quote
