Here is my version from while back:
www.rockauto.com prices for 3/5SFE)
GATES TCK199 (kit of timing belt with two pulleys and instruction)
$84.79
GATES Part # K030295 PS belt $4.32
GATES Part # K050435 Alt/AC $12.12
FEL-PRO TCS45641 Cam seal $4.11
FEL-PRO TCS45920 Crank seal $6.04
BCA Part # 221820 Oil pump seal $2.71
AISIN (Toyota #16110-79185) water pump $58.79
FEL-PRO VS50304R valve cover gasket set $13.94
I think you should also consider doing the
valve stem seals (~$40) while at it (your timing belt and valve cover is off anyway). Get a FelPro set. Older Toyotas used a cheap rubber on the intake and caused some blue smoke startup problems. Also consider
NGK Iridium-IX plugs.
Originally Posted by Retrospekt
I found a local mechanic and would like to obtain all the parts I need for a complete timing belt service myself to save money.
The car has 148,500 miles on it and has never gotten the belt changed. It's leaking a lot of oil from what I suppose is the oil seal and the rest of the seals in this area.
The exterior belts (alternator, power steering) look new, so those can stay.
That being said, what parts do I need to do a full service so that I'm good for another 60k miles?
Thanks guys.
