i was driving to the movies and my car cut off .thinking maybe it was gas since gas light came on i added about half a tank worth but the car still did not start. i tried some starting fuel and it worked. so i let the car rest for after about 5-10mins and the car started as if nothing happend so i kept driving and it cut off again after about 10 mins of driving. since it did not want to start again i decided to park it since i had no money for a tow truck.
The following day i went back to my car and it started up with no problem. so i drove it back with my friend following me just incase she didnt make it. right when i got there it didnt want to start up again. very weird. so i pulled out my hanes manual thinkin maybe its the fuel pump dying out. i opened the diagonostic connecter cover and jumped FP and +B to see if the fuel pump would work and it did but before jumping it the pump did not make any noise as if it worked. so then i tried the EFI relay in the fuse box near the intake and when i touched it, it was hot. i dont know if thats normal but i thought it was weird. anyways i took it out and tested like the manual said and ended up wit continuity on pin 1 and 3 and non on 2 and 4.
so now the problem i have is find the curcuit open relay i think but i cant seem to find it. maybe they didnt make it for my 92 camry but theres suppose to be 3 relays on the fire wall toward the passanger side but theres not one there.
does anyone have any idea on what the problem is???
o by the way the car started again after i tested the fuel pump and EFI relay. seems like after the car cools down it starts up.
