97 camry driver side mirror - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2009, 12:07 PM   #1 (permalink)
View dcninja757's Photo Gallery
I hit a pole at an atm with my driver side mirror, now the glass in it is all loose and the electric control won't work with it, I'm thinking something popped out or soemthing, hoping I don't need a new mirror... anyway- how do I remove the mirror so I can look at it and check it out (also so if I need to replace it I'll know how) thanks!
dcninja757 is offline   Reply With Quote
Old 08-14-2009, 12:21 PM   #2 (permalink)
View gyz1893's Photo Gallery
I found the mirror itself on ebay for about $20. If I were you, I'd rather throw in another $10 and get the whole mirror assembly. If you want to replace the whole assembly, you have to remove the inside door panel to disconnect the wires that go to it. That is as far as I know. If my guess is correct, you have to remove the triangular black piece closest to the front of the door (on the interior side, of course). Once you have removed that, take out the screws and the mirror assembly should come loose.
Mirror alone:
http://cgi.ebay.com/ebaymotors/97-00...Q5fAccessories
Whole Mirror Assembly:
http://cgi.ebay.com/ebaymotors/97-98...Q5fAccessories
gyz1893 is offline   Reply With Quote
Old 08-14-2009, 12:44 PM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
If the coloured plastic housing is not damaged or cracked, slip your fingers under the mirror and pull, it will pop off.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 08-14-2009, 01:57 PM   #4 (permalink)
so i can just pull the glass piece out? I think it just got knocked loose and I need to pop it back...I will try that now.
Old 08-14-2009, 02:06 PM   #5 (permalink)
ok mirror glass wouldn't go back on it cracked, so now I just need a whole new mirror assembly. lol
Old 08-14-2009, 03:35 PM   #6 (permalink)
lol. well ebay has them for a cheap price. just buy one and install it. The procedure shouldn't be hard at all once you unplug the wire and remove the black triangular piece. It's pretty much straight forward.
