Help Radiator fan won't stop rotating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2009, 02:56 PM   #1 (permalink)
Fspekion's Avatar
View Fspekion's Photo Gallery
I have a 2001 Camry...the radiator fans keep rotating even when the ignition is off and the key is turned to the ON position.
It should normally stop rotating after a few seconds when the ignition is on at cold temp right? This time it just keeps going...
What may be the problem? Help me.
'01 Camry LE [5SFE]
Fspekion is offline   Reply With Quote
Old 08-14-2009, 06:26 PM   #2 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
most likely a bad coolant temp sensor. its designed to turn on all the time if the sensors fail
rusty9 is online now   Reply With Quote
Old 08-18-2009, 06:21 PM   #3 (permalink)
Fspekion's Avatar
Thanks for the reply. Yes, it's either the temp sensor or relay.
'01 Camry LE [5SFE]
Old 08-18-2009, 07:31 PM   #4 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
My car was doing the same thing.......couple guys at my local dealer I know spent 2+ hours going over it with me. FINALLY, 1 of them had an idea. Turned out to be a bad AC pressure sensor. Saying too much freon in the system keeping the fans on whenever the car was in the "ON" position, running or not.
5 Lug Corolla WHAT?
Old 08-20-2009, 07:14 PM   #5 (permalink)
Fspekion's Avatar
But I haven't added/replaced the freon...
'01 Camry LE [5SFE]
Old 08-20-2009, 08:06 PM   #6 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
That doesn't mean the sensor can't go faulty mate.
whip_cracker is offline   Reply With Quote
Old 08-21-2009, 01:00 AM   #7 (permalink)
Kyle_Mains's Avatar
View Kyle_Mains's Photo Gallery
On my 98 avalon the ECT temp. switch went bad, cost me 60 something dollars and about 2 months of slowly trying to figure out what was wrong.
Check the relays first tho.
SQ > SPL
Throwing 1,000 watts of rattle in your trunk does not mean you have a "system".
Kyle_Mains is offline   Reply With Quote
Old 08-23-2009, 12:28 PM   #8 (permalink)
Fspekion's Avatar
Thanks guys. The problem was somewhat similar to ASG14's problem.
Apparently there was a restriction in the condenser, so it created a high pressure that keeps the fans rotating all the time.
'01 Camry LE [5SFE]
