02 Sensor Replacement?
Ok. My brother is away in the military, and im trying to get his car ready for him when he returns. we do not live in the same house. (lived with his mother) so i don't know his driving habits, and no one in the house hold seems to know whats going on either. He has a 2001 Camry 2.2L 4 cyl. It has a check engine light on so i took it to autozone and the guy told me it was a upstream 02 sensor issue. Well.. also. the exhaust flex connector (bradied exhaust tube that hooks the header pipe to the rest of the exhaust.) is done. leaking so bad that there is barley any exhaust coming from the tailpipe. these 2 problems, and me being fairly fimilar with cars. (just not having access to helpful info) im almost conviced that the 02 sensor is NOT bad. despite what autozone told me. at $150 im recultant to buy one and have it not fix the problem (turn of check engine light) i dont have a schematic of the sensor, its connectors or its wires. but we have 2 black wires, a blue and a white. I used my multimeter, i managed to figure out 1 black wire was the B+ the other 3 were....? (so its a H02S) so first are these prone to fail? 2nd how can i check to verify the sensor is good...or bad using a multimeter? 3rd. because of the huge upstream exhaust leak (before the CAT) could the fact that 1 is seeing 02 levels straight from the engine? and the other seeing near atmosphere 02 levels? or even 4th could it be something completely something unrelated. like a MAF or PCM? any light shead on this subject could help alot. thanks.
