HID problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2009, 10:09 PM   #1 (permalink)
View r3v0's Photo Gallery
HID problem
I have a dual filament (HID xenon / Halogen) H4 bulb for my 99 Camry.
here is my problem i can wire my HID or Halogen to work correctly as a low beam.
however when i turn on my hi beams the headlights flicker and go out.
example:
HID xenon are wired up for lo beam.
turn on low beam, HID get powered and everything is fine.
now turn on hi beams, halogen flicker on and dies out.
then i have to turn off all the lights and turn on lo beams to get them my low beams to work again.
i hope that the 4th gen ppl out there can help me out. what is my problem, is it because there is not enough power? or do i require another ground?
r3v0 is offline   Reply With Quote
Old 08-16-2009, 09:36 PM   #2 (permalink)
View Marcluv's Photo Gallery
4th Generation
did you purchase the Hi/lo kit? If not you will always get that, if im correct. Because it only has one bulb but im not sure lets see what other people say
Marcluv is offline   Reply With Quote
Old 08-17-2009, 04:52 AM   #3 (permalink)
yes, mines is a hi/lo bulb.
it is a dual filament bulb, meaning it has a HID xenon and a halogen fitted into a single bulb.
the bulb is a h4 bulb this is a 99 camry, 4th generation camry
Old 08-17-2009, 08:24 AM   #4 (permalink)
4th Generation
I was going to get my hid package today but now I'm a little worried. Do you think I should get the 9003 kit insted of the h4 kit? And also what's ur brightness 8k,10k?
Old 08-17-2009, 08:49 AM   #5 (permalink)
maybe this will help you out....
http://www.stealthauto.com/Products/...__HID-CAP.aspx
Old 08-17-2009, 08:49 AM   #6 (permalink)
its called an Anti Flicker Capacitor
Old 08-17-2009, 10:32 AM   #7 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
Get a hid relay harness.
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 08-18-2009, 01:53 AM   #8 (permalink)
http://cgi.ebay.com/ws/eBayISAPI.dll...m=230366947282
is that what i should b looking for?
i asked the seller and they said that i require a bi-xenon HID harness, is there a difference?
to verify, having a relay harness will fix my problem with my halogen hi beams dying out after a short period.
Old 10-05-2009, 05:34 PM   #9 (permalink)
where did you mount your ground wire, my left headlight wont turn on,i thinking its because of where i mounted my wire. i mounted my ground on the radiator support bar.
Old 10-05-2009, 06:16 PM   #10 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
you mean your colour temperature. your output is only about 3200 lumuns, but the colour is the diffrence with 5400k and up. (5400k is about a normal sunny day).
also it seems to me your problem is you dont have bi-xenon projectors, so that means you dont need the high beam your blinding all traffic anyway.
^ and leaving it that way!
