"Shocking" experience with my Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2009, 05:20 AM   #1 (permalink)
View tundra2287's Photo Gallery
Exclamation "Shocking" experience with my Camry
I was wrapping up the chore of changing my spark plugs the other day and went to check my connections at the distributor cap......nothing loose, took nothing apart, nothing moved......and it shocked the pee out of me. Does anyone know why this might have happened?
tundra2287 is offline   Reply With Quote
Old 08-17-2009, 08:59 AM   #2 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
only way it could have happened is if it was running... and your wires and/or cap have a crack in them. and some other part of your body was grounded to the body or engine block somewhere. you became part of the circuit. suggest replacement of cap and wires.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 08-17-2009, 09:12 AM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
why didn't you disconnect the battery? I always do that when messing with plugs and wires...
Old 08-17-2009, 10:04 AM   #4 (permalink)
Gibson99's Avatar
because you shouldn't have to. electricity is only running thru the plugs and wires when the engine is running.
you should only have to disconnect the battery when working on starter, alternator, and maybe airbags. or maybe main fusebox issues where you have to take apart the harness itself.
98 Camry CE v6 5s
97 MX-5
www.gibson99.com
Old 08-17-2009, 11:37 AM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
ah i see. i seem to be a bit overprotective sometimes, good to know hehe at least i won't have to reset clock and radio stations after tune-up next time
on the other hand i used to touch plug wires on running engine too, right after I replaced them with new ones ugh ... will remember that i wasn't supposed to.
Old 08-17-2009, 11:56 AM   #6 (permalink)
Gibson99's Avatar
i've touched them too and been shocked when i wasn't careful. if the wires are in good shape you shouldn't get zapped. as long as you aren't touching the end of course!
another good test i've heard of is to run the engine at night with all the lights off, and if you can see arcing electricity around the distributor or wires, then you know they're worn and need to be replaced. of course this isn't the "de facto" test for cap n wires, but it's one that almost anyone can do.
98 Camry CE v6 5s
97 MX-5
www.gibson99.com
Old 08-17-2009, 12:19 PM   #7 (permalink)
View Piledriver's Photo Gallery
Just make sure that any time you might be working with a live wire, you put your left or right hand behind your back and only touch the system with one hand at a time
That's so you can't make a circuit through your heart.
I don't know what sort of voltages/currents you're looking at in various parts of a car, maybe someone else can chime in on whether it's DC or AC and how much
Piledriver is offline   Reply With Quote
Old 08-17-2009, 04:45 PM   #8 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
Spark plugs and wires are DC and I'm not sure what the average voltage is on our cars, but it's really high, somewhere in the range of 20,000 volts, as for amperage I can only guess, a few milliamps on a good day. It will jump you, but there isn't enough current to do any real damage.
They charge a coil which creates a magnetic field around it, when power is removed from the coil the magnetic field collapses and creates a very high voltage spike in anouther coil which is wrapped inside of the first coil, but not connected electrically to the cars battery, it's like a static shock really.
SexieWASD is offline   Reply With Quote
