P1410 97 Camry V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2009, 10:41 AM   #1 (permalink)
muminiasty's Avatar
View muminiasty's Photo Gallery
4th Generation P1410 97 Camry V6
I went to Autozone and they gave me this code
P1410
Valve possition sensor circuit malfunction
probable cause-
BB1 Open or short circuit condition
BB2 poor electrical connection.
.Where should I start looking. I cleaned the throttle body white smoke covered the neighborhood and all that. Engine light is still on. I attached the picture of one of the sensors.Should I start replacing sensors? Light is on and off. usually it comes back on in the morning when I start the car. Thanks a guys.
muminiasty is offline   Reply With Quote
Old 08-17-2009, 02:14 PM   #2 (permalink)
View evoicon06's Photo Gallery
4th Generation
I got that same code and i just replaced the egr positioning sensor and the CEL went away...
http://www.google.com/products?q=97+...ng+sensor&aq=f
This sensor is on top of the throttle body/egr area...i bought mine at autozone for $31...the dealer wanted $65 for it
evoicon06 is offline   Reply With Quote
Old 08-17-2009, 04:11 PM   #3 (permalink)
muminiasty's Avatar
I ordered one online. Will replace it as soon as it comes. Thanks
Old 09-09-2009, 10:32 AM   #4 (permalink)
muminiasty's Avatar
Installed new sensor but light showed up anyway. Is there different sensor as well?
Old 09-10-2009, 12:08 AM   #5 (permalink)
Sorry for the late response but after you installed it did you reset the computer? basically remove the negative terminal of the battery then reconnect it like 10 secs later....
i had to do this...but if its still not the problem i suggest you get a haynes manual those things are life savers
Old 09-10-2009, 12:28 AM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Or pull the EFI (5A) fuse for a minute. It saves your clock and radio stations.
Old 09-10-2009, 07:11 AM   #7 (permalink)
muminiasty's Avatar
I reset the computer but light comes back on , not right away but after a day or two. Do you think that other sensors could give the same code??
Old 09-10-2009, 08:35 AM   #8 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862610
View BamZipPow's Photo Gallery
You might want to pull the EGR and clean it...if not, then yer looking at replacing it.
BamZipPow is offline   Reply With Quote
Old 09-10-2009, 01:51 PM   #9 (permalink)
muminiasty's Avatar
I took a look at EGR valve today, other that simple 3 bolts on the front it has two bolts on the back that connect to the pipe. How the hell do I get access to those?? Is it better to disconnect the pipe on the bottom and pull everything up??
Old 09-10-2009, 01:52 PM   #10 (permalink)
muminiasty's Avatar
By the way light if off again when I turned the car on. ANNOYING !!!
Old 09-23-2009, 08:40 PM   #11 (permalink)
muminiasty's Avatar
Light went off for now. we will see later
