Cig lighter works for the lighter, but not for a cellphone charger - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2009, 10:54 AM   #1 (permalink)
View 17seconds's Photo Gallery
Hi there
I have a 1996 Toyota Camry with a strange problem.
The Cigarette Lighter works perfectly when I push in the cigarette lighter.
i.e. It gets hot in less than 20 seconds!
However if I try a cellphone car charger in there, it just wont work.
No little light or anything.
I've tried several chargers in there and all of them work on other cars besides the Camry.
Any suggestions?
17seconds is offline   Reply With Quote
Old 08-18-2009, 11:08 AM   #2 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Originally Posted by 17seconds View Post
Hi there
Any suggestions?
Hmmh. Dunno, I've had at least 4 different cell chargers and they all worked fine in both of my '95 Camrys...
eddie926 is offline   Reply With Quote
Old 08-18-2009, 04:32 PM   #3 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
The socket is likely messed up.
5 Lug Corolla WHAT?
Old 08-19-2009, 01:39 AM   #4 (permalink)
Do you think changing the Lighter socket will fix the problem?
Is it not something else to do with the fuse?
Old 08-19-2009, 01:55 AM   #5 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Pop off the bracket and look at the cabling in the back. When I looked there were 2 connectors. Maybe one of them controls the back panel (the part that makes contact with the cigarette lighter) and one controls the side wall. Hey, it's worth a shot.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 08-19-2009, 12:05 PM   #6 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
i've seen sockets get corroded if someone uses the actual lighter a lot. that corrosion prevents making a good contact to the small center pin on a power adapter, but since the actual lighter is much larger it can still make contact. look down inside the socket to make sure nothing is corroded/rusted or gunked up with ash or something. if it is, clean with a wire brush or pick.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
