Distributor O-ring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2009, 03:25 PM   #1 (permalink)
View Suprarush's Photo Gallery
Canada Distributor O-ring
Hey guys
I have a 92 Camry V6 3VZFE. Is there a step by step here for doing the distributor o-ring? Let me know when taking the distributor off how precise I need to be for the timing.
Also I seem to be losing power steering fluid in my reservoir, I don't see any leaks so I'm wondering if its the high pressure line. If it is, what do you guys recommend?
Suprarush is offline   Reply With Quote
Old 08-18-2009, 10:01 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
For setting the timing, either mark the head and the distributor with liquid paper before removing or get a timing light. For the PS, take a good look at the boots on the rack and the hoses. You can see the lines better by getting under the car.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 08-18-2009, 10:09 PM   #3 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Both lines that come off of the P/S cannister are high pressure (I'm pretty sure).
How to test it: Put a clean piece of cardboard under your car (large piece). Turn the car on and in park, start turning the steering wheel all the way to the left and all way to the right. Do this for a few minutes. If you take the cardboard out and it has small droplets all over the place, you have a small leak in your P/S hoses.
If it's not that...inspect your rack and pinion.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 08-18-2009, 10:54 PM   #4 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
There is a website based outta Canada where you can buy the dizzy seal and bearing kit to service the dizzies from the 3VZs. Not sure on the website anymore, someone here might have an idea. As for a guide, I wouldn't know where to start.
Apparently my O Ring needs to be replaced as well... I'm not too worried as the oil comes out the other end anyway and isn't causing any problems. I guess if it's leaking only a tiny bit, then I wouldn't be too worried. If the O Ring needed replacing and wasn't leaking, it'd be building up and probably causing more problems. I would replace mine, but when I service my car every 5000km, I get the mechanic to just wipe the oil off.. simple as that.
whip_cracker is offline   Reply With Quote
