I have a problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2009, 10:51 PM   #1 (permalink)
View Gman94's Photo Gallery
I have a problem
ok so my GF has a 93 camry 4cly auto and it has what seems to be an oil leak. it looks like its coming from where the oil filter screws on because its all around that and its all over under the car like on the oil pan and everything. has anyone had this problem before or knows what is causeing it like a bad seal or something?
http://www.cardomain.com/ride/2484831
1995 geo prizm: header, hi flow cat, full stainless steel catback exhaust, Short ram intake, custom functional hood, body kit and converted to manual.
Gman94 is offline   Reply With Quote
Old 08-18-2009, 10:55 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
IMO, it may be as simple as overtightened oil filter (broken gasket) ... or maybe it's loose ?
Old 08-18-2009, 11:01 PM   #3 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Drain the oil, remove the filter, check the gasket... see if there's any marks. Replace the gasket onto a clean surface too though... get a small amount of oil and lightly grease the gasket/rubber and make sure it's not overtightened.
Had this problem once - my mate used a crap filter and thought that "the tighter, the better" with his new dan-dangle oil filter wrench was awesome and got over-enthusiastic with it.
Make sure it's on, make sure it won't come undone and make sure it's not too tight :P lol
whip_cracker is offline   Reply With Quote
Old 08-18-2009, 11:03 PM   #4 (permalink)
Ill have to check that tomorrow I just noticed that it was really bad when we got home cause it was smoking from all the oil on the engine I personally didnt do the oil change she had a shop do it so it could be they didnt tighten it all the way or something, but it has done it before it just looks worse this time.
Old 08-18-2009, 11:11 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
may have been a crappy filter ... 3/4 turn makes it tight enough (follow instructions above). don't drive it when loosing oil, if it's peeing she may have lost quite a lot already.
here you go, official DIY from Toyota
http://www.toyotaownersonline.com/pu...Oil&Filter.pdf
Old 08-18-2009, 11:21 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Does the car have an oil cooler? If the oil cooler gasket (like the gasket on an oil filter) has never been changed then it could be a possible source of your problem.
Old 08-19-2009, 12:06 AM   #7 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
make sure on some occasions that the filter doesn't have two gaskets coming from between the block and the filter. This could be caused like everyone said an overtightened filter and the old gasket got stuck to the block. Then someone replaced it with a new oil filter on it so there's two gaskets.
RU2CHKN is offline   Reply With Quote
Old 08-19-2009, 08:30 AM   #8 (permalink)
Im not sure what it would look like if it did im not familiar with the camry. its got what looks like an adapter that has hoses comeing from it and then the filter screws onto that is that the lines for an oil cooler?
Old 08-19-2009, 09:45 PM   #9 (permalink)
View HI85WH1's Photo Gallery
EXACTLY!
Mine leaks there too but I'm a lazy azz... I'll fix it during my next oil change.
HI85WH1 is offline   Reply With Quote
Old 08-19-2009, 10:42 PM   #10 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
see this
i had this problem. i changed this whole thing (only because my old one didnt leak). what you need is the gasket off a oil filter, take that off and change it. bye bye leak.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 08-20-2009, 11:34 PM   #11 (permalink)
dont they make a gasket for that tho? or is using one from an oil filter better?
Old 08-21-2009, 12:47 PM   #12 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
Off Topic.
You have an awesome Geo dude. A+
deezeejoey is offline   Reply With Quote
