Gen 3 Headlight Adjustment/replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2009, 10:43 AM   #1 (permalink)
View ravenglass's Photo Gallery
3rd Generation Gen 3 Headlight Adjustment/replacement
HI GUYS
93 Camry V6 LH headlight vertical adjustment seems to be stripped and I need to lower the beam. Am going to pull off and try to shim - any advice. If this doesn't work will buy Depo lights but am concerned about fit as car was built in Japan and dealer p/n for headlight is different from US built cars, - again any advice.
Thanks
Ravenglass
ravenglass is offline   Reply With Quote
Old 08-19-2009, 11:33 AM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
im sure depos will fit your gen 3. i had bought a set of depos with the intention to retro/install but unexpected events lead to one thing and ended up with no funds to buy the rest of the parts...anyway
i also have a japan model
by the way i have the clear depos for sale brand new... if you are interested
Old 09-08-2009, 11:04 AM   #3 (permalink)
Interesting - removed headlight assy. from car and then separated lens from carrier so as to get at beam adjustment mechanism. The beam up/down is by turning the vertical rod at the back of the assy. which is splined at the bottom and engages in a right angle plastic 'gearbox' . The 'gearbox' output turns a 'nut' which moves a threaded rod fore /aft which in turn terminates in a plastic ball joint on the back of the lens so as to tilt the lens/beam up/down when the adjustment is made. My problem was simply that the vertical rod had been pulled up and the splines were not engaged in the 'gearbox'( dealer?). Easy fix.
