stereo plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2009, 10:45 PM   #1 (permalink)
View m.nfs.p's Photo Gallery
4th Generation stereo plugs
in my 1998 i had a tape deck and i dont like it so i went to a junk yeard and found a cd player that worked only thing is the plugs don match with the existing plugs in my car. i have a 4 cyl and the cdplayer i pull was from a 6cyl, can some one helpme please
m.nfs.p is offline   Reply With Quote
Old 08-20-2009, 11:21 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
If you have a camera, take a photo of the back side and post it here. That V6 might have JBL setup.
2007 Camry 2.4L 5M
Old 08-21-2009, 12:10 AM   #3 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Orrr... if you know what you're doing, you can make some 10cm cables with these on the end of them:
These can be pushed straight into the existing harness for the power, earth, acc, speakers etc etc and then get some PVC tape and wrap around a few times to make sure they don't fall out. It's better than hacking up the existing harness and takes only a few mins. The connections are solid and have worked for me each time.
Just a suggestion...
whip_cracker is offline   Reply With Quote
Old 08-21-2009, 07:24 AM   #4 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Some Camrys had head units with internal amps. Some had head units that used an external amp(upgraded models).
The HUs with internal amps had two wiring harnesses that plugged into the back. The HUs with external amps only had one wiring harness.
Camrys that came with the external amp HU also included additional harnesses for plugging in a unit with an internal amp, so a swap was easy. Camry's that came with an internal amp HU don't have the external amp, so you can't just swap in a factory external amp HU.
eddie926 is offline   Reply With Quote
Old 08-21-2009, 07:26 AM   #5 (permalink)
View skuttduck's Photo Gallery
Sounds like the CD player you got was from a system that had the factory amp. I've posted a few times the link to Crutchfields wiring diagram for the AMP on the Camrys.
I'd do what whip cracker said and plug those connecters into the back of the stereo...
There is another option, can you cut the wiring from the car you got it out of, and then get the reverse wiring harness to plug it into your car.
http://www.sjgreatdeals.com/sista02rb.html
skuttduck is offline   Reply With Quote
