dome light will not shut off ??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2009, 11:47 PM   #1 (permalink)
View sw1980's Photo Gallery
dome light will not shut off ???unless i switch it off !!!
The door pins do register on the dash.
It doesn't turn off the dome light it gives me the door open indicator on the dash. if i have the doors open.Why wont the shut off???
thanks
steffen
98 camry v6
sw1980 is offline   Reply With Quote
Old 08-22-2009, 07:53 AM   #2 (permalink)
Gameroom cash: $303255
Remove the door pins from each door and check them for rust on the back. The pins simply complete the circuit when the door is open causing the dome light to go on. There may be enough rust on the backside so that the rust is bridiging the normal gap that is there when the door is closed and thereby completing the circuit. Clean them up with a wire brush and use some dielectric grease so that the rust should not return.
Mike
Old 08-22-2009, 08:32 AM   #3 (permalink)
if its the door pins ....wouldnt the light on the dash the shows the door open not work?which it does ...if you open the dorr it will turn on if closed it turns off.just checking?
Old 08-22-2009, 12:58 PM   #4 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
I think for now, just remove the bulb until you get a chance to take the panels off.
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 08-22-2009, 11:20 PM   #5 (permalink)
so what controls the shut of ?what kinda fuse or relay ?
Old 08-23-2009, 11:01 PM   #6 (permalink)
Old 09-04-2009, 03:26 PM   #7 (permalink)
any advise????
