Vibration on front end - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2009, 10:55 AM   #1 (permalink)
View wjd03's Photo Gallery
Hello all, I searched a bunch of threads looking for any info on 93 front end problems . Just did not see anything resembling my problem. I get a nasty vibration on the drivers side front at acceleration and just gets worse the faster it goes. The brakes look good and the tire has no play in it sideways or in/out.The drive shaft may have a bit of wobble in it (I dont know what is normal). Could I have a bad bearing in there because the wheele gets very hot when I'm done driving. Any help figuring this one out would be great
wjd03 is offline   Reply With Quote
Old 08-22-2009, 12:55 PM   #2 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
It can also be a warped tire, or bent rim. Also check to see if your calipers are stuck. Those are some possibilities
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 08-22-2009, 01:27 PM   #3 (permalink)
re
Calipers are not stuck,wheel was swapped out what next? CV joint axel. I wonder because I dont know about if or where bearings would be located in the drive axel as a part or seperate the can be replaced
Old 08-22-2009, 02:23 PM   #4 (permalink)
cruisn76's Avatar
Most wheels get hot because of friction or under inflated tires. Is only the driver tire hot?
Unfortunately I don't know where the bearing sits so I can't help you there.
Old 08-22-2009, 02:30 PM   #5 (permalink)
swapped out a bad tire still have a little vibration in the steering wheel. Wondering if its an alignment balance problem
Old 08-22-2009, 09:25 PM   #6 (permalink)
Gameroom cash: $160210
View FLIP K1DD's Photo Gallery
if you know its not your cv axle or tires, it might be motor mounts. i recently replaced my mounts and everything is better.
FLIP K1DD is offline   Reply With Quote
