Dayum. That's some difference mate.
Not that it matters, but Toyota manufacturers Non-interference Engines. Meaning, if the timing belt snaps, nothing would happen to your cars valves. They are designed never to collide with the heads as the pistons go up the cylinder unlike other cars you see on the road. Your car would just roll to a stop. The only inconvenience would be you'd stranded for a while until somebody comes to pick you up. But however, a well tuned, good tension belt is good for the water pump and oil pump. For a car as old as yours, it may be a good idea to have a look at those or replace the cam, and crankshaft seals and the oil pump o-ring while you are in there. Also take a careful inspection of the water pump. There is a DIY for those somewhere here if you can find it.
Camry 99, V6 LE Black w/ kits & bronze alloys
