help needed and ideas with projector retrofit problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2009, 11:23 AM   #1 (permalink)
View 07civiclx's Photo Gallery
4th Generation help needed and ideas with projector retrofit problems
OK. bought the following
tsx projectors
Anzo gen 4.5 clear/chrome headlights with halo's
Osram bulbs and hella replica ballasts
this is a double wammy retrofit on this camry, as its a 98 and they are 00-01 headlights
SOOOOO
made the harness, it works like a dream, highbeams and lows beams work together perfectly when high beams are hit on.
MY QUESTION IS AS FOLLOWS!!!!
Upon cooking the first headlight in the stove for 10 mins @ 175 degrees, i ran into a problem.
(this is my second retrofit all together)
When i began prying at the headlight with a flat head screw driver, the plastic began cracking a crumbling (not the face plastic, but the rear what looked like metal, plastic.)
OK. WTF!!!
this doesnt happen with OEM headlights, so clearly these are poorer quality.
I need to know if ANYONE knows how to get these 4.5 Anzo headlights apart!!!
ive seen the retro done before without a hitch on here, but i clearly am doing something wrong, or i got a cheaper version somehow!!!!
ideas people!!!!
07civiclx is offline   Reply With Quote
Old 08-24-2009, 11:05 PM   #2 (permalink)
View TMetalMan's Photo Gallery
How about a higher oven temperature? I usually do about 250 deg. for about 8mins, and haven't had any issues. For you this should make the plastic a bit more pliable, and less prone to cracking.
TMetalMan is offline   Reply With Quote
Old 08-25-2009, 09:46 AM   #3 (permalink)
i ended up using a heat gun and screw driver anyways. i only cracked one small section of the headlight that ill repair with epoxy. its not a visible spot neways
MODS close thread!
