What should I do next? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2009, 03:17 PM   #1 (permalink)
View tkearins's Photo Gallery
My 95 camry (from previous thread) has been stalling (but not shutting off) while accelerating. It started off just doing it when I was running the A/C. Then after a few weeks it was doing it while running A/C and then for 10 minutes after shutting the A/C off. Now when I start it up, it runs great for about 10 minutes, and then without even using the A/C, it begins to stall when I accelerate, especially from a stop.
I fixed a leak in the air-intake duct and that didn't help.
I tried changing the fuel filter (never been changed, 187K miles!) but couldn't get the bottom nut off, and neither could my mechanic, who said he would break the fuel line if he tried any harder, so I can't change the filter now.
What should I do next? Keep in mind this Camry owes me NOTHING, its been great to me. The mechanic says I should just drive it, stalling and all, until something major comes up and then scrap it. Someone at work advised me to get a new fuel cap, because maybe thats it. Any suggestions?
tkearins is offline   Reply With Quote
Old 08-24-2009, 06:12 PM   #2 (permalink)
I hate mud!
stuckTaco's Avatar
View stuckTaco's Photo Gallery
Check the ISC (Idle Speed Controller) it's on the bottom of the throttle body.
stuckTaco is offline   Reply With Quote
Old 08-25-2009, 10:50 AM   #3 (permalink)
this may be a dumb folllow up question...but if the idle air control is faulty, wouldn't the car idle badly too? this problem only occurs when I put my foot on the gas while driving. It idles fine, and it also revs fine when I'm in park and revving the engine.
I'm definitely going to check the IAC, but is there anything else it could be? do you think the gas cap could have anything at all to do with this? or my severely cracked radiator which I have to top off with antifreeze on a daily basis?
Old 08-26-2009, 01:20 AM   #4 (permalink)
View Camry LE 94's Photo Gallery
you might as well rip the fuel line to get the filter off. thats what i had to do. the line ran me like 60 bucks. when is the last time you did a tune up? and how about the coil in the dist. cap?
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 08-26-2009, 09:49 AM   #5 (permalink)
where would you get a fuel line? Every site i go to (advance auto, autozone, etc.) have the line going from the filter to the carburator/engine, but I can't find the one going from the gas tank to the fuel filter.
How likely is it that this is the problem? And why would it start and run fine for 15 minutes, and then start acting up once its warm?
Old 08-26-2009, 11:56 AM   #6 (permalink)
Gameroom cash: $275055
Did your mechanic ever put a fuel pressure gage on the fuel rail and check the actual pressure, both cold and hot? Weak fuel pumps can cause problems when they get hot. Also, at the mileage you have on the car the coil inside the distributor can act up as they too get hot. Your mechanic can check that easily with a digital volt/ ohmeter and the specs from any manual, or you can do that yourself if you have access to a digital volt/ohmeter. Also visually inspect the coil for hairline cracks.
Mike
