OK, guys, it's me again...
My brothers told me that there's nothing worse than a woman with a ratchet set, and NOW, I'm inclined to believe them... Here's the story... Some of you may be familiar, some not, anyways...
96 Camry 5SFE...
Changed the TB, WP, Crank seal, Cam seal, oil pump o-ring, and the WP housing. All OEM parts. I did the job per DZ63's DIY... I did it once in December, and all went fine, but now, on the same car, same job, it won't start... The first time I did the job, it was because the WP took a dump, and made the TB snap. THIS time, I used OEM stuff (I didn't the first time, which is why I had to do it again)... I thought the WP went out again (I used a Vato-Zone WP the first time), because it started to over heat, and leak coolant on the WP side of the motor...
I thought it may have been the HG, so I did a compression test to confirm that, and got good numbers, so I proceeded with the WP change. Now, mind you, after doing the compression test, the car started and ran fine, because I had to move it into a better spot to do the WP job...
Anyways, I do the job, get the stupid thing buttoned up, try to start it, and crank, but no start. Checked the timing - SPOT ON!! Fuses and relays look good, battery is good, alternator is NEW, I also just put a new distributor cap and rotor on it today, but still no joy. The spark plug wires only have about 2-3000 miles on them.
What the hell else could it be??
