Change plugs on '98 V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2009, 04:35 PM   #1 (permalink)
View CamXLE's Photo Gallery
Question Change plugs on '98 V6
Hi all,
I'm hoping some one can tell me how to change the 2 spark plugs next to the firewall closest to the passenger. I think I can get to the one closest to the driver. I would like to avoid taking the throttle body off. I tried reaching the middle one with my hand while leaning from the driver side, but when I gripped the plug boot, my forearm would expand and get squeezed in all the brackets and hoses. Help! My next Camry will be a 4 banger!
thanks!
CamXLE is offline   Reply With Quote
Old 12-03-2011, 03:22 PM   #2 (permalink)
4th Generation
Well, it been a while since I posed, thats a good thing, I don't like working on my car or spending money on it. I spend more time on my wife's newer Saturn.
Anyway, I can't remember where I got the info for the plugs change but I found it. The recommendation was to use two shorter extensions to make the bend but I used a socket extension of the right length, took it slow so as to not cut my self or smash my knuckles and contorted my self to reach the reclusive plugs.
Old 12-03-2011, 03:28 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
grats you found the info.
yeah, there are many ways to approach V6's rear bank plugs, but my favorite is to take 2 6'' extensions (1 of locking type) and a union joint (to make the bend). it also helps to have a solid spark plug socket ... mine unfortunately popped off the rubber insert on the spark plug #5 LOL ... gave me a moment of terror, but it was an easy fix after all.
reminds me that I need to finally glue that rubber insert to spark plug socket metal walls ...
Old 12-03-2011, 07:22 PM   #4 (permalink)
View duke_togo's Photo Gallery
You might find this thread helpful: Spark Plug Change 1MZFE Engine - The Easy Way.
1996 Toyota Camry V6 LE (1MZ-FE A541E), gone, but not forgotten.
2006 Toyota 4-Runner SR5 V6
2011 Toyota Prius
duke_togo is offline   Reply With Quote
