The ends were cut off but i beleave there is two bunch of wires coming to the radio , one for power and one for speakers. First thing i would do is add a ground strap to the radio chassis . THEN its a prosses of elimenation , unhook all speakers try differant ones, then maybe unhook all but the needed power leads. There should be two one for memory ,, one for thats switches on with the key , take off the memory one ,,, just to see if it helps. Is there a lead for the dash lights , so when you turn up the brightness on the dash the stock radio would get brighter allso ,, maybe thats hooked in some how. As a last resort try a dif radio, seems weird it works ok untill the lights are put on ,,,, will it work ok with the parking lights on ? Can you post your wireing diagram or say what you think each is?
