Yea. Like they said here. And also know this, the low fuel light indicator is not any normal on-off light with a transistor driven relay circuit. Its a U44 Solid state thyristor driven relay circuit. Semiconductor companies don't even manufacture 'Thyristors' anymore (used in Voyager spacecraft mission). Meaning, as the fuel goes low, the light slowly starts glowing. More intense light means, very low fuel, and then it stays on. The intensity of the light is proportional to the resistive load from the float as it bobs up. This is very hard to notice because of the small orange transparency/light bulb. That circuit has a very VERY low failure probability and high tolerance. Chances of an internal circuit failure is almost impossible even on a direct collision.
(by the way, the Voyager 1 satellite built sent up in 1977 is still functions and relays back info, still does its self diagnostics and has flown past Neptune and Pluto, has gone past our solar system, into deep space and interstellar space, has gone farther than any man-made object ever built. The reliability of those electronics is unmatchable by any modern technology.)
Camry 99, V6 LE Black w/ kits & bronze alloys
