3vzfe bad fuel economy - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2009, 07:28 PM   #1 (permalink)
View ivan300's Photo Gallery
Question 3vzfe bad fuel economy
Hey guys i just bought a camry with the 3vzfe engine. It has 136k miles on the odo. On my first fillup i got 13MPG haha and i babied it. The car drives and idles fine. The check engine light is not on. The car does feel a little underpowered though.
So im wondering what are some of the commong things that go bad that i should replace?
I ordered the full engine gasket kit, so im gonna replace the valve cover gaskets. Oil filter housing gasket and anything else thats leaking.
I will also change the plugs, and check the wires and distributor tomorrow. Also check for any vacum leaks.
What else should i replace and clean that will affect my fuel economy.
ivan300 is offline   Reply With Quote
Old 08-26-2009, 08:59 PM   #2 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
as i advocate for all 3vz owners: advance timing and lean AFM mixture. if your only getting 13mpg something is wrong maybe a bad patch of gas.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 08-26-2009, 11:00 PM   #3 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Hmmm...
Fuel system cleaner, injector cleaner, change spark plugs, replace fuel filter, run better fuel...
Yeah, that'll fkin change it hehe
whip_cracker is offline   Reply With Quote
Old 08-26-2009, 11:02 PM   #4 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426253
View EEngineer's Photo Gallery
clogged cat and old O2 sensors
trust me, this is ur problem
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 08-27-2009, 03:55 AM   #5 (permalink)
The guy with a maroon 92
n3rdifed's Avatar
View n3rdifed's Photo Gallery
could you direct me to how i can do this? and are there unbenefical effects or risks of doing it?
clogged cat...never thought about that
n3rdifed is offline   Reply With Quote
Old 10-04-2009, 04:02 PM   #6 (permalink)
Hey guys so this is what i did so far
- New Fuel filter
- Spark plugs
- Rotor/Cap
- set timing to 17
- leaned out the afm 3 clicks
- New o2 sensors
I am still getting 13mpg. Though i am driving 90% city but i have been babying it. It should be getting at least 17+
Im tempted to pull out the cat and gut it.
Any other ideas?
Old 10-04-2009, 04:19 PM   #7 (permalink)
Born to Drive
EEngineer's Avatar
yea do that..cat can be very problematic
also, try seafoam and clean ur EGR?
and pop ur vavle cover and check for sludge
Rest in Peace
Old 10-04-2009, 04:47 PM   #8 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
let me ask what grasde of fuel you are running. the 3VZ requires premium fuel. do you have a manual or auto trans? are you calculating mileage as a combined city/highway on a full fillup? with my 92 SE with the 3VZ and a 5spd i see around 18mpg in the city and 24+ on the highway if i'm conservative. you may also want to inspect your air filter. a clogged air filter, improperly inflated tires, clogged fuel injectors, and improper plug gap/type can effect fuel economy.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 10-04-2009, 05:44 PM   #9 (permalink)
I am running 87 octane as per the manual
I have a auto tranny
The calculated 13mpg is combined with mostly city
The air filter is clean just checked it
I just checked the tires, 2 were 30 and 2 were 26. I inflated them all to 35
The fuel injectors could be clogged. I ran some cleaner in the tank but i doubt that does anything
The spark plus i installed were pre gapped platinum tipped plugs.I was getting the same mpg before i changed the plugs
Old 10-04-2009, 06:48 PM   #10 (permalink)
mazdaverx7's Avatar
with the 3VZ-FE, you shoud be running 92 or higher, per the manual. not that it will make a huge difference, but the tire pressure specs are 32psi front and rear.
85 RX-7 GS 5spd
Old 10-04-2009, 06:52 PM   #11 (permalink)
91 RON = 87 Octane
If im not beating on there is no reason to use premium.
Old 10-04-2009, 06:56 PM   #12 (permalink)
mazdaverx7's Avatar
i wanted to add that removing the fuel injectors and sending them in to be cleaned may really restore performance and economy. i use a company called witchhunter performance. their turn around is only about five business days and their work is outstanding!! their website is www.witchhunter.com
85 RX-7 GS 5spd
Old 10-04-2009, 06:58 PM   #13 (permalink)
Born to Drive
EEngineer's Avatar
yea there's no point in dumping premium in 3vz
Rest in Peace
Old 10-04-2009, 06:59 PM   #14 (permalink)
mazdaverx7's Avatar
Originally Posted by ivan300 View Post
91 RON = 87 Octane
and that may be fine. i always go by the book and use 93 octane and my fuel mileage numbers are consistant. i wouldn't think that octane rating would really make that big of a difference from your 13mpg to a factory quoted 18mpg city.
85 RX-7 GS 5spd
Old 10-04-2009, 07:16 PM   #15 (permalink)
mazdaverx7's Avatar
even with a 9.6:1 compression ratio, there actually is a point. the engine will run far better and performance will increase. the ecu can recognize higher octane fuel and will adjust the timing based on the octance level. the higher octane fuels are better for your engine and the internal engine components such as the valves and pistons, will be cleaner because there are more cleaning agents in the higher octane fuels.
85 RX-7 GS 5spd
