Originally Posted by Jimnist
Sorry, but you kinda can't. From now on, you'll be blinding oncoming traffic with your glare, no matter how you adjust it.
if hes got a gen4 and not 4.5 then HIDs work fine with the stock housing but only with a bulb shroud. i never blinded a soul and could easily adjust them.
Originally Posted by RU2CHKN
On the gen 3 there are two screws that you turn to adjust them. The one screw on the top adjusts the light vertically while the other screw in the back adjusts them horizontally. Not sure if the gen 4 are the same.
the gen4 ones are about the same. the adjustment screws are just in a slightly different location. but they work the same...left and right adjustment is loated on teh inside of the headlight and the up and down adjustment is a small silver phillips screw on the other side.
